      05-17-2011, 04:24 AM   #9
z4mnyc
z4mnyc's Avatar
14
Drives: Z4 M Coupe
Well... the ride height was not the issue in my case, it was rubbing at the back of the liner when the wheel is turned. Take a look at the photos above
I had some rubbing with the R888s as well but it was not too bad as you can see from the scuff marks. The Hoosiers however rubbed significantly at this spot AS WELL as against the shock strut and I would not have been able to drive the car without modifying the liner and the use of a 10mm spacer
First track day on the Hoosiers is this Thursday. We'll see how it goes...
| Z4MC | KW Clubsport | BBS-RGR 19 + Bridgestone RE11 | BBS-RGR 18 + Hoosier R6 | Sparco DTM RS | Vorshlag mounts | Braille battery | Euro Headers | Supersprint exhaust | Stoptech lines | Stongstrut | TCK camber arms | UUC SSK | APR GT-200 wing & splitter | ESS Tune | Speedware Motorsports custom roll cage | Schroth harness |
