Z4M's use the E36 front knuckle which can be shimmed. For people looking for cheap camber, this is typically the first route. I personally never did it, but you should be able to find more info searching. However, I don't think it will give you enough to fit a 9.5...plates are best option...what tire/size were you planning?
