Originally Posted by pungo
Sounds like something is drawing current from the battery ofter the key is off. Connect an amp meter inline with the battery. If there is more than a few hundredths of an amp with the key off, start pulling fuses until you find the culprit. From there, more info would be needed to diagnose.
Wow I totally forgot to say this..after I cut the car off...coming form the left door area I keep hearing this. fump fump noise like the door lock is cycling or
the ventilation system is still pumping air, I will go check the fuse's now.
