Originally Posted by jnkhan82
Yikes!
If I do have to replace the motor, it would just be the Hydro unit ( 54347193448 $390) or would I have to get the whole Hydraulic unit (54347079586 $1,200) ?
Also, When you pull the lever in the trunk, so you have to pull it every time you want it to go up and down? or just once? and if once, how do you make it go back to the Hydro unit? dumb question, but I don't have access to the manual at the moment.
thanks
Unless you have a seal leak on either the left or right hydraulic cylinders, then the only parts you need are the motor and I do recommend you replace the motor housing (Sound Insulation) at the same time,
There is a very good DIY on how to do this.
