Originally Posted by Devious21
Do you remember which code you were getting?
This is most likely the hose # 11-15-7-834-056 we had to modify for the Evolve install. I'll have to check how it's doing. Hopefully an easy fix. Should be completely unrelated to the header install.
Still no clue on this one.Anyone have any insight on this?
The generic code I was getting before was P120d, I believe. Not sure if that relates to either of the two above.
It's possible that none of my codes are related to O2 issues. I'm just paranoid since the wires were snipped during the install.
FAULT #2A11.
Here is the description of the job.
J# 2 10B14Z06 CHECK ENGINE LIGHT TECH (S):186 WARJWITY
CUSTOMER REPORTS"CHECK ENGINE'/SERVICE ENGINE SOON' WARNING COMES ON.
PERFORMED A SHORT TEST AS NEEDED.I FOUND DMTL FAULT #2A11 MINOR LEAK DETETCTED.
I PERFORMED A DIAGNOSES LEAK CHECK USING GT1. I FOUND NO LEAKS DETECTED.I THEN PERFORMED
A SMOKE LEAK CHECK.I FOUND THE TANK BREATHER VALVE IS LEAKING AT SEAMS.THIS IS THE ONLY LEAK FOUND.
REPLACED THE TANK BREATHER VALVE AS NEEDED. CLEARED FAULTS AND ROAD TESTED.ALL OK AT THIS TIME.
NO DIAGCCOE, MECHANICAL FAILURE.
PARTS ------QTY- -FP-NLAtER...............DESCRIPTION--------------------UNIT PRICE-
JOB #2 1 13-90-1-831-770 FUEL TANK BR BM WARRANTY
