2CEC:
Check your throttle rail to make sure it's not rubbing on anything and that it's clean.
Maybe hit it with some WD-40.
When I had my air box off to do a motor mount swap I meticulously cleaned the throttle bodies with CRC Throttle Body Cleaner and a tooth brush and cleaned and WD-40'ed all the moving parts of the actuator system.
