Originally Posted by Mtxzptlk
Do you have a pic?
I just had my kit installed today. If I follow what you're describing, then my answer would be that there is no gap. The opening of the airbox closest towards the front bumper is pushed up against the rubber neck/gasket of the stock intake through the bumper.
I'm wondering if the rubber neck should be left in or removed? I get a whistling sound when I initially get on throttle. Not sure what is causing it or whether it's good or bad. So far no engine lights from the tuned file that Evolve provided. Car feels like it runs smoother, good response etc. etc.
I removed the rubber gasket to have better fit.
