Originally Posted by The HACK
Did you guys get the shorter of the 2 10mm support rods, or the longer? On APR's website there's 2 versions, one goes from 6.5" to 8.75", the other goes from 8.5" to 10.5"?
It looks like they supply the shorter one with the splitter. So I would stick with the shorter one, unless you are interested in using extreme angles (mine is perfect IMO - most people usually go a little less extreme).
