Originally Posted by Finnegan
Silver only. Looks like what Beta posted. Tightened only enough that they're adjustible. Retraction is a bit slower, but snapping the belt quickly still seems to engage locking at the same rate as before.
I've noticed if I pull the belts straight down, instead of across, they don't bind. So I've just gotten in that habit to avoid it. When I go to retract them, I do the same in reverse.
But even when I open mine WAY up, so they don't seem to touch at all, they are in a position that has reduced the max travel by almost 2 full inches
I have thought about trying to coat them in something slick that wouldn't cause as much friction to the belt.
