Originally Posted by eujiji
Has anyone had success with touch ups for Black Sapphire Metallic? I've used Dr Colorchip on my BSM car and the initial color match looks good, but the blending solution makes the touch up paint dull down to a flat black. The touchups still remain noticeable because of this, otherwise I would agree it works fantastically...
For chips larger than the size of a pin, and deep enough to go past clear coat, you don't use the blending solution. You dab the paint into the chip and wait for it to dry, then build up until it's almost even with the surface, then you polish off the excess before it fully dries and cures.
