Thanks again for the replies, Kgolf31 & The HACK.
I ended up getting the wheels rebalanced and Discount Tire said the front 2 wheels were slightly off-balance. Now, I'd say that the wheel hops that I felt are 30%~40% less than before, but not gone. Maybe the rest of the wheel hops is just from the dampers and springs (440lbs front springs). I have SA dampers so I can't change the compression; rebound is at 1/4 turn from full soft so I'm not sure if I should go softer.
I'll just keep the current wheel alignment until next spring/summer and see if I get used to it.
