      02-03-2016, 12:03 AM   #1
SaltyNC
SaltyNC's Avatar
370
Drives: 2006 BMW Z4M Roadster
Gruppe-M Z4M Intake Install PDF
Anyone that has installed a Gruppe-M intake knows the included instructions leave a bit to be desired. It is a fairly easy installation, and very few tools are needed.
Tools:
Small Flat Head Screwdriver
Large Flat Head Screwdriver
Phillips Screwdriver
Torx Security bit (tool included)
Channel Lock Pliers (may not be needed)
Allen wrench (included)
Metric socket set and ratchet is handy but not necessary for attaching nuts to bolts.
Please see the attached PDF. If there are any errors or omissions, please let me know, and I'll add corrections. I hope this is helpful.
Salty
