Originally Posted by car62
The photo in post #18 is an air hose, not an oil hose. The VANOS oil pressure accumulator and the oil line going to it are bolted on to the side of the passenger engine mount. It could be easily damaged if the mount bolts broke and this would result in a high pressure oil leak.
Which is exactly why the bolts should have been RECALLED, not just had a TSB...
