Two people lift the hardtop into the correct mounting points. Use the tool provided to lock the sides and top center into place. Plug in the wire for the rear defroster. You will probably have to make adjustments to the top due to wind noise. That information can be found with the sear tool, but involves the adjustment nuts where it mounts on the sides.
