      12-20-2009, 07:29 PM   #18
racerbruce
racerbruce's Avatar
3849
Drives: 21 X3 & 13 335is E93
oz ultraleggeras....z4m roadster fitment
i luv oz's...had an 18 in set on m s2000.
looking to purchase these (below) for the 07 z4m roadster....will these fit?
oem 18's:
front: et 42
rear: et 30
oz 18's:
front: et 40
rea: et 40
O.Z. Ultraleggera
Finish: Black Painted
Front Fitment
18x8
Offset: 40mm
Backspacing: 6.10"
Bolt Pattern: 5-120
Rec. Tire Size:225/45-18
Weight: 18.6lbs.
Rear Fitment
18x9
Offset: 40mm
Backspacing: 6.57"
Bolt Pattern: 5-120
Rec. Tire Size:255/40-18
Weight: 20.8lbs.
