Originally Posted by pal
Adam - while you test fit, can you also check if they will work with shorter studs (a little less than OE)? I have a set of new KW Clubsports sitting at home to replace the V3s and I was wondering if I need longer studs with the RE brace. I needed them with the OE brace.
Tx.
Pal
You will definitely need the longer studs.
The studs on the clubsports are shorter than OE.
Adding anything extra & they are too short.
IDK why they make them that way.
