1st, after trying out the new module (white convertible controller) repost if that fixed your issue.
My posting was based on your original post which suggested that the top never worked after you put it in.
If the new module doesn't do anything.
"Top going down at an angle." When you installed roof did you get both sides of the U inside the clips on each side of the car?
How low was the fluid you topped off?
