Originally Posted by inTgr8r
Many others including myself did this coding without faults.
If it was the coding you would think that others would have the same result that you are experiencing.
Right only asking because it doesn’t actually show up on dash. It only shows up if you go out of your way to pull (shadow) codes. I enabled DTC and disabled TPMS same day and I’m trying to determine what’s a real issue vs coding done incorrectly.
