      05-11-2011, 08:02 PM   #7
z4mnyc
z4mnyc's Avatar
14
Drives: Z4 M Coupe
Originally Posted by cgroppi View Post
Shorter tires would fix the problem. Why don't you go with 245-35s in front and 285-30s in back?
I run 285-30 A6s in the *front* for autocross, and don't get any rubbing. They're on stock wheels which squeeze the hell out of them, but they're still wide. The 245-35s are about the same diameter.
Tirerack will let you return tires if you haven't driven on them. You should be able to exchange them for the other sizes (although you'll be out the shipping cost).
Not a bad idea, I will consider that.
| Z4MC | KW Clubsport | BBS-RGR 19 + Bridgestone RE11 | BBS-RGR 18 + Hoosier R6 | Sparco DTM RS | Vorshlag mounts | Braille battery | Euro Headers | Supersprint exhaust | Stoptech lines | Stongstrut | TCK camber arms | UUC SSK | APR GT-200 wing & splitter | ESS Tune | Speedware Motorsports custom roll cage | Schroth harness |
