Originally Posted by alvinli217
mine opens with just holding the unlock button
i thought this thing was suppose to work without needing to hold on the unlock button to have the top down.
the only thing i see different is the windows go back up after the top is down
Okay....this module (RCH+) does the following:
1) when using console buttons for top down - single button push, let go, and top goes down - no holding down until process is done (top down)
2) Same as # 1, but in reverse order.
3) Key Fob - top down - same as factory, but you do not need to hold unlock button.
4) Key Fob - Top up - North American models do not work - this unit allows top up with key fob - unlock, unlock, lock combo, then release, top goes up now, as well as windows up, and doors lock.
Not just windows up as some thought.
I hope this helps....
