Good info in your Mod thread, I didn't know that the heat shield needed modifying. You didn't need to remove the airbox for the install did you? I think if your not doing motor bracket bolts that removing the section of intake with the MAF would be enough. I need to shift my motor mount bracket around a little to get the last two Motorsports bolts installed. So my intake is definitely coming off. I'll be starting my install on Wednesday.
