      07-26-2015, 08:34 PM   #383
intoflatlines
intoflatlines's Avatar
Drives: Z4MR, E34, E30
Originally Posted by Bossdog View Post
I have a Z4M Roadster
I have seen several ask and comment about:
245/40/18x9 ET42
275/35/18X10 ET25
on stock suspension. Will this work with no Modifications, Spacers or fender rolling?
I thinking about Apex ARC 8 with RE-11's for autocross. 5 lbs/rim lighter than stock!
It will just be casual AX, so I want to be conservative, not create any rubbing issues, but get as much rubber down as I can.
You will clear with no problems at autocross or daily driving. However, if you install camber washers you will need 5mm spacers on the front to clear the struts.
I have BFG Rivals and ARC8, same specs that you mentioned.
245/40/18x9 ET42, 275/35/18x10 ET25
