      03-12-2015, 02:25 PM   #378
Arsonism
Arsonism's Avatar
Drives: '08 M Coupe
Originally Posted by blitzkrieg989 View Post
I think I found my answer but just want to run it past you experts. Plans are apex arc-8 wheels.
F: 18x9.5 et 35 with a 255 probably gonna have to be a 245? Might need a 5mm spacer?
R: 18x10 et 25 with a 275?
Use: street and autocross mainly maybe even track eventually.
Suspension: stock for now with plans of going with KW V3s in next 6months.
No spacer needed you will be perfect. Just get some meaty tires you're good to go.
When lowered may or may not consider moving out from 245-255 // 35 to 45. Otherwise no real change should be necessary.
Originally Posted by 08z4mroadster View Post
Got a set of 18" Work Emotion from 335i
Front:
18x9.5 +23
Rear:
18x10.5 +30
Will those fit for the Z4M?
Your rears will probably be rubbing without some camber (unless it hits a perch on your suspension - inner clearance is cutting it close I think). Fronts will most likely be fine.
