If I recall correctly, the two bolts that tighten down the airbag is hidden under the multi-function buttons. Which means the buttons need to come out before you can access it.
It has been a while though (nearly 10 years since I last removed an airbag on the Z4). When I get home I can fire up the TIS to double check.
Nevermind...
