      06-23-2010, 04:35 PM   #8
JD3
Drives: 09 e92 M3, DCT.
Originally Posted by misterawa View Post
You can run with a 19X9.5" rear wheel with a 35 offset. On my last set of wheels (Miro Type 366s) i ran a 19X8.5" front and 19X10" rear with a 35 offset all around. I recall someone running a 32 offset in the rear.
Keep in mind that these measurements are with 265/30/19 rear tires.
Thanks, that helps a lot.
So if you're running a 35 offset on a 10" then you should be safe with as low as 29 I'd say on a 9.5". At least that's what my math would say. 25 is probably still too aggressive, even with 265/30's.
