      11-24-2013, 02:59 PM   #53
WestCDA
Drives: 2006 Z4R 3.0si
Originally Posted by Clearancediver View Post
I also went with the longer sized battery. There was a insert in the battery well of my 2004 Z4 3.0i which I took out (specifically installed by BMW for this reason) which allows the longer battery to be installed.
Good info, thanks for the update.
I guess I didn't look hard enough at the design of the bottom plate when I picked up the first battery, and will use the longer H6 next time. Don't think it makes too much difference for my needs, to be honest - with the new H5 battery I've never had a problem with starting the car. The car will drain it down eventually, if I leave it stored for an extended period without a float charger on it.
