Originally Posted by dubsesd
Park against a wall and see if the steps in the cutoff are at the same level. Looking at the car from the front, and kneeling down the cutoff should show up first in the drivers side headlight. Auto leveling calibrates the projector itself, it doesn't re-align the projector. You have to manually adjust them with a hex key after lowering. Takes 5 minutes
Dubsesd - can you elaborate a little? "Steps in the cutoff?"
I have these autoleveling on my e39... and have noticed that they stopped autoleveling and that the headlights are exhibiting the same problem that Dubbed describes... hoping i can fix mine too.
