Originally Posted by seank
Spring rates would be helpful for him to use this information, as well as sway bar sizes if they are not stock.
500#front 600#rear, it's in his sig.
OP - TCK was probably talking about a staggered set-up for wheels. I've talked to them and they recommended going a 10.5 rear wheel.
10-12mm spacer will be perfect. APEX I know recommends 12mm.
Personally, it all depends what you want to achieve. Do you need more tire to power down (although you can achieve this by more toe-in as well) or do you want rotate tires? and eliminate understeer?
