      12-19-2018, 12:06 PM   #61
GuidoK
#buildnotbought
GuidoK's Avatar
10859
Drives: Z4 3.0i ESS TS2+
Originally Posted by Z4C17 View Post
Hi. Anyone can help please or insight.
When I press the open top button there's a light but nothing else happens. The window doesn't go down. No response from motor latch. I don't know what's wrong. I have read a lot but most of them have the issue of not opening but unlatch and motor works.
Rear microswitch that detects if the top shelf in the trunk is up or down.
Common failure.
part #12
http://bmwfans.info/parts-catalog/E8...p_compartment/
btw your profile states that you drive a coupe. Are you sure you have a removable softtop?
StickMon636.00
