While they may fit in both, I think you'll find they click into only one. You can see that each female fitting has a notch on the side that is opposite each other.
The male should also have a side notch. But the female will click onto the male when inserted the correct way (I hope). Maybe try one connector in each, then tug on it. The one that's harder to remove the male from should be the correct one.
But I haven't taken this apart myself so it's only a guess. good luck
