Originally Posted by Mtxzptlk
Need spacer advice on the following sizes for flush fitment.
Also am running KW CS coilovers.
F 8.5 x 19 +32
R 9.5 x 19 +28
Thanks in advance
Do you already have it on the car and want to modify it further?
I have the same wheel size with 245/275 tires. My front spec is the same (+32) and find it to be perfect. I did +20 on rear for several years. Very very slight rub on the top of the fender (no major damage). I recently took out the 5mm spacer and still find +25 to be attractive. Since you're at +28 now, a 5mm spacer should be perfect. If you want more aggressive stance, you'll need quite a bit more camber or skinnier tires.
