Does anyone know if it is safe to use a 400 lbs/inch spring in the front when the average rate of the progressive is 220 ?
I want to get the Clubsport springs and helper springs but this guy in the customer support of KW is having some problem communicating with me with technical info.
All he says is that you will not feel the difference between V3 damper and Clubsport damper and i am failing to understand why?
