Originally Posted by 3point0
What about a vacuum forming / drape moulding process? Around the exhaust might be an issue but for regular body panels that might be an idea. I often get clear acrylic pieces drape moulded at work and you can create some pretty complex shapes if the material is thin enough and handled correctly
Thats a possibility, however the plug or parent part/donor won't like the high heat and may become damaged or warped afterwards if not built into a solid form first. It would be sacrificed in other words.
I'll see what my friend says about letting be pull molds from his ACS diffuser and associated bits.
