Originally Posted by Nate4641
Not trying to thread-jack, but does that camber have any negative effects on the wear of the tires?
do not put camber on a daily driver!! my e46 has just under 5 degrees in the rear,which is extreme, to fit 18 x 11s et 35 and i can only get about 8k miles on the tires before they are trashed.
Im trying to minimize camber on the z4m, but with stock suspension, will 9.5s fit in the front without rub, maybe with spacers?
