Well bumping this back up.
My right front wheel is still shaking in/out of the engine bay (like you would do when you do a shake-down for wheel bearings)
I'm getting a squeak and movement on the wheel. When I was in tech today for autocross and I was able to apply light pressure like I was shaking the wheel bearing (while laying on the ground) and the shock actually moved along the shaft when the car was jacked up
Could this lead to a blown shock?
