      11-15-2012, 09:26 AM   #87
Kream
Drives: 07 M Coupe, 11 GLK350
07 Black M Coupe, 95K miles as of this morning. Some issues but most are wear and tear. Oil change every 3-5K miles. New fluids for transmission and diff every 30K. Valve adjustments at 30K, 60K, and 85K.
Clutch safety switch @ 28K
Washer pump (warranty) @ 30K
Warped front rotors (warranty) @ ~32K
Washer pump again (replaced with aftermarket) @ 70K
1 Ignition coil @ 85K
New battery @ 85K
1 Fuse (forgot for what)
Washer pump is working but pumping very weak @ 90K
New alternator @ 90K
Rear pads @ 93K
Having airbag light issue coming on once a month. Thinking about doing the E46 M3 bypass since there wasn't a recall for our cars.
