      12-19-2012, 12:53 PM   #3
mike519
mike519's Avatar
Drives: 2018 M240i
You can run the 255 on the 10". But unless you plan on very wide rear tires (track use) you might want to go with 9.5 rear. You can run a 275 on that size wheel, and there's less chance of rubbing, as well as lighter weight. The ET22 looks aggressive as well in the 9.5 size.
Thanks for the advice, I may just go that route.
