Originally Posted by ZStig
The ecu will adjust itself to add more fuel. My new fuel pump will be good enough to provide it. Installing next week i hope. I will avoid going over 6500rpm even with the new fuel pump until I get re-tuned. There is a risk of running lean at WOT at high rpm and blowing up
So far im reaching 5-6psi before 6500rpm with partial throttle. 75% throttle, 4500rpm and the tires are slipping
Who will maKe your tune?
Just fuel pump or also bigger fuel lines and lower fpr? Which pump? Radium?
