Sounds pretty good all things considered
Started up fine - 30 seconds after I turned the key for the first time took this video. Let it warm up a bit - slowly revved it up to about 6500 and eased off and it just went up and down smoothly. In fact first time started it went right to about 1400 RPM and after a couple minutes went back to 900-950.
It used to turn over - start up go to 1500 and then drop and almost stall and then catch and go back up - didn't do that either
Waiting on the one piece power steering hose and if better than the one with 3 pieces and 4 clamps will take a picture.
Note that some pics are not of what you are looking at and are also not matched with the directions - take your time - All in all - not bad - better than exhaust work !!
Hans at ESS was a great help and again -= the installer should have a couple hours under a hood or he would be toast.
