Originally Posted by F360C
What size tires are you running?
255/40 18 - the fronts are an 18 x 9 et38 wheel. I wanted this size because it is identical to stock rolling diameter and, since these wheels have never been run on a Z4M before, I honestly didn't know of anywhere else to start. Since it's a front wheel, a smaller diameter tire wouldn't affect the speedometer however, what about traction control?
Originally Posted by MFGJR
Sorry to hear they're rubbing.
Thinking about increasing negative camber using shims, how much clearance do you have now between the inside of the tire and the strut? I only have about a finger's width with my stock wheels and 225s. Might be forced to do it from the top . . . hello, camber plates!
FG
I do not know how much room there is between the inside of the tire and the strut. I bet not much, but it's not rubbing so there must be enough... I thought about trying to put more camber into it to help, but as said before, it's a matter of millimeters in reality.
