Originally Posted by Finnegan
Is this a ///M coupe or 3.0?
A bit of front toe-in should help, as Sean noted, but I wouldn't go too high on that.
Tires make a bid difference as well, I and if they're run-flat that makes it even worse.
Here's a link to a resource on alignment by Z model. If yours is an ///M I can be a lot more specific with recommendations.
mine is ///M
can you help with alignment? Mostly street use and occasionally track.
note i got KW V3's installed. would want max camber (even sides), but how about the toe, pls?
