      02-25-2015, 11:00 AM   #4
GuidoK
#buildnotbought
GuidoK's Avatar
10859
Drives: Z4 3.0i ESS TS2+
Originally Posted by torchmedia View Post
Don't tell me, already available somewhere else?
Yes, 15 years ago they invented something called torrents
The only thing of importance is what version is this / what languages / what chassis are supported.
Running it as a virtual PC is rather cumbersome. Why would you do that? What is the OS on the image?
The TIS version that usually goes around is ported from a unix enviroment to windows (the standard exe is supported up to winXP but there is an easy workaround for win7/8). Originally TIS is installed as a 'plug in' in DIS (which is unix based).
I have it running on a win8 tablet. Works nice with the touch screen
You can ditch a lot of data from TIS if memoryspace is tight on a tablet. There is a load of crap on the install which is needed for certain wheel alignment software..... (I think about 700mb or so)
