Originally Posted by Rickson
Hi everybody,
I am a new proud owner of a black 2006 Z4M coupe (bought from a member of zpot) .
In canada it is not obvious to find affordable CSL wheels. I find a local seller for this set http://vacations.kijiji.ca/c-cars-ve...AdIdZ447508381
Could you confirm me that the size wheels is ok and maybe give me an idea of thr brand?
Thank you
so....
i'm pretty sure those are actual OEM CSL wheels. read: not NA ZCP's... real CSL's. if you can confirm this (have them send you high res close up pics of the text surrounding the center caps) and they are in good shape, then 700 is an EXCELLENT price and you should not hesitate.
-eric
ps- the pics should produce the last 7 digits of the OE part numbers. only BMW used this technique.
