      01-17-2013, 10:18 PM   #18
liamduong
liamduong's Avatar
Drives: 2007 BMW Z4M
Rear diffuser is ACS Schnitzer from Euroactive
I'm using OE tires. They fit very well. Does not look stretched at all. You should get at least 10mm spacers for the front, depending on the offset. I have 5mm spacers in the rear. I might even go with 15mm for the front and again, all depending on the offset.
