Originally Posted by Chuck I
Running diagnostics with the GT1, I am able to see the DME respond to the Sport Button. It actually shows the button toggle on and off. However, the EPS (electric power steering) says the Sport Button is always OFF.
just wanted to clarify with you. does this mean that the EPS is not adjusting when the button is pressed? I had thought you did a test and the results showed a significant change in steering response
