Originally Posted by inTgr8r
You can definitely make them work.
The fronts are fine as is but you might want to add ~15mm spacers on the rear to flush them out a bit.
What are your tire sizes?
Thanks, perfect. I was thinking about spacers when I originally put them on the 3.0si since they aren't flush but never got around to it. I think it will really help on the M though.
The tires are stock size. 225 front 255 rear.
