Originally Posted by Aries326
Thanks for sharing your maintenance schedule. Did you do the VANOS solenoid cleaning yourself? How difficult is it?
Yeah I did it myself. It's quite easy to locate and easy to clean. I've seen other members dunk it in gas over night to clean but I brake cleaned it so I could put them back same afternoon.
The hard part is putting the solenoid back in. It's a f***in pain because its so tight to angle the part back into the engine. Its completely doable you just have to be persistent and try every single way till it goes in.
