      08-17-2011, 09:48 AM   #166
Beedub
Originally Posted by Roffle Waffle View Post
9psi
nicee, so you have my pulley basically and your higher rpm allows boost to climb alittle higher as you get another 300rpm???
awesome, just keep an eye on AFRs...... your car must feel like a rocket!!! mine sure does!!!
remember we are basically seeing vt2-550 boost ;-)
450rwhp is easy number wih our boost numbers, with my cool climate... ppooowwwweeerrr!!!
remember clean runs with banging the rev limiter, and post a pic please!!!!
edit just seen your pic!!! your tune will pull timing after 7900 anyway due to ess safegaurding your motor, can you do some runs as if youve got stock redline @ 7900 and post up your peak pic please!!!
i.e 1st-3rd changing @ 7900 then post your peak ;-)
how does the car feel?? im guessing violently fast, can you also cut loose in first and second?? i think low 11s is definatly possible with the correct tyres, your opinion on that??
