      05-10-2011, 10:47 AM   #38
tarheel91
Drives: ESS Z4 3.0i
Originally Posted by Dark Schnitzer View Post
I do get SOME tire rub when under full suspension load and hard cornering...but not terrible and only for a nano second.
19"x9" and 9.5", running 245-265 respectfully.
Is your sidewall ratio still 40 up front, 35 rear?
Also, as v3.0si, what's the offset? The last owner says mine is at stock offset which I assume is 47 front 50 rear. I haven't tried to confirm this, though. I can see how 9's would rub in the front with an offset in the 30s.
