The 570 is MAF less, but I'm not sure if it's running a set map at WOT (open loop). I'll have to do some research and see if this specific ECU runs in open loop ever. If VF can't fix the issue with tuning, then I'll definitely have to do pressure tests to make sure everything is up to par.
